Or is even using your thumb to flick it out damaging as well?
Technically, you're "supposed" to be guiding the blade out by holding the thumbstud and rotating it out till it clicks into place. Absurd, of course. What you are describing puts so little force on the stop pin, it isn't hurting it at all. I like to do that with my Sebenzas, because they have that smooth-but-moving-through-molasses action. Just the right amount of force, snapping the blade forward, will drop the lock into place. Elegant!Originally posted by Marcelo Cantu
I try to train my muscle memory to use only just enough force to get a soft click of the lock engaging, kind of like a game of mine.
Originally posted by sc_rebel1957
Personally I'd be a little suspect about buying any knife the maker worried about dammage from simple flick openings.
A properly made knife should wear in not out, Yeah I know this is gonna enrage the Sebbie crowd!
Stop pins are hardened for that reason and shouldn't flat spot no matter how many times you flick open the blade.
Originally posted by Easyrider
If flicking is so bad for knives then what about the assisted opening knives from Kershaw?
