The Flitz, being 3 micron, we can expect to work a bit slower and more importantly, to need more stone work prior to stropping. The Simichrome being 10 micron will extend its reach noticeably I would expect.
I have not worked with either, how different are the binders? Does one tack up faster or start out tackier than the other? I would expect the Simichrome to haze over fairly quickly, this will anchor it more and even if it were the same particle distribution it would work faster.
David, how much more aggressive than Flitz was the Simichrome when applied to the hard maple, if at all?
The fatty emulsifiers are likely stearin, a thinner version of what most compound binder is made from. Since it isn't a suspension in ammonia, it will take a long time to dry/migrate out. It also forms a thin layer, not much, but thicker than the powdery layer made by the Simichrome. At that scale it will make a difference and really tone down the Flitz.
I need to buy some of this stuff...
Yeah, Flitz does have an interesting odor. It reminds me of old cigarette lighters for some reason. They call it non-toxic, but then again, they also call it non-abrasive.
http://www.flitz.com/faqs/
As far as Quick-Glo, would Lava Soap work in a similar capacity? It also has pumice.
"Stainless is considered a hard metal, and the oxidation or tarnish is difficult to remove and frustrating to keep off."
How would you polish/clean up electroplated silver?
Cleaning tarnish from silver/silver plate is easily done with Tarn-X. It's available at most grocery stores in the cleaning aisle. Clean silver usually looks very dull. It has to be polished.
POLISHING Silver is easily done with Simichrome. Of course, if the plating is already thin, you can polish through it, but that will happen with any polish. Simichrome used gently is the cat's rear end for silver or silver plate. It doesn't take much. A tube of Simichrome lasts me 5-6 years, and I'm in the restoration business.
Though I'm no expert on silver like Mr. Herman, I do have considerable training in the jewelry industry. Mr. Herman certainly likes tools!
"Chemical Tarnish Removers (These are just a few of the products that will absolutely ruin the original finish on solid silver and silver-plate. They also allow tarnish to form more quickly.) Read about these dips here.
Ellanar Dip Instant Silver Cleaner
Empire's Instant Tarnish Remover
Goddard's Silver Dip
Hagerty Silver Dip
Medallion Care Tarnish Treatment
Midas Silver Tarnish-Off
ShineBrite Silver Dip
SilverMate
Tarn-X
Weiman Instant Tarnish Remover
Wright's Instant Tarnish Remover
