Times 10!!I get that people here like to analyze every tiny detail... I just think some are over-thinking it.
Nobody is suggesting polishing the edge on purpose. If you can't imagine incidental contact possibly happening such that a blade gets dull then...I mean I don't know, but people say it has happened to them before and suggest watching out for it.Times 10!!
And can be applied to a whole lotta posts across the site!!
Well said John!!
John![]()
Our pocket knives will become dull by actually using them to cut stuff. Therefore, worrying about some accidental contact with the cutting edge by a polishing cloth should be a non-issue in the grand scheme of things. I'd be more worried about the edge cutting through the polishing cloth and into your finger. Just take caution to keep away from the cutting edge when polishing your blades and all will be good.If you can't imagine incidental contact possibly happening such that a blade gets dull then...
Thanks for letting me know what's important and that knives dull when you cut stuff.Our pocket knives will become dull by actually using them to cut stuff. Therefore, worrying about some accidental contact with the cutting edge by a polishing cloth should be a non-issue in the grand scheme of things. I'd be more worried about the edge cutting through the polishing cloth and into your finger. Just take caution to keep away from the cutting edge when polishing your blades and all will be good.
How so?
Sorry, my reply was meant as a general reaction to the point you brought up... not really directed at you in particular.Thanks for letting me know what's important
Flitz is a non-abrasive and does not remove metal.When you use it Flitz on a cloth to polsh a blade you can see the steel it removes on the cloth. It has a very fine abrasive.
Then what is the grey material on your polishing cloth? Per Obsessed with Edges the SDS for Flirz shows it contains an abrasive, aluminum oxide,Flitz is a non-abrasive and does not remove metal.
It’s a chemical reaction between flitz and the metal being polished, not “removed metal”.Then what is the grey material on your polishing cloth? Per Obsessed with Edges the SDS for Flirz shows it contains an abrasive, aluminum oxide,
I think you should go to the Flitz website and read the FAQs, rather than watching YouTube reviews and forum commentary from third parties, IMHO.Aluminum oxide won’t react with steel, but as an abrasive will remove it w/o leaving scratches.
Yes, I don't bother polishing any store bought knives. The only reason I experiment with various polishes is to bring out the hamon in a hand made knife that I'm making myself.It's clearly too dangerous to use on knife blades, crucial dimensions and all....
I don't watch Utube and Obsessed with Edges has proven to be reliable. I also know what aluminum oxide is. As noted by Flitz Cusomer Sevice, Flitz is abrasive, but beneath the level the USG requires it to be called abrasive. It wouldn't work w/o the abrasives.I think you should go to the Flitz website and read the FAQs, rather than watching YouTube reviews and forum commentary from third parties, IMHO.
Let’s play “what does this mean?”I don't watch Utube and Obsessed with Edges has proven to be reliable. I also know what aluminum oxide is. As noted by Flitz Cusomer Sevice, Flitz is abrasive, but beneath the level the USG requires it to be called abrasive. It wouldn't work w/o the abrasives.
You mad?Your forum name kind of undermines everything you write. Hard to believe you know jack. Keep on truckin![]()
