ScarFoot
- Sep 16, 2021
Another simple way to help decrease the temp swings (depending on how your toaster controls temp) is just to put a heavy piece of metal in it to hold heat and preheat for an hour before starting your tempering run. Toasters generally aren’t well insulated and have very little mass to retain heat. Your toaster probably controls to +/- 25 degrees of set temp if your getting a 50 degree swing. Mine isn’t that bad but I also keep a heavy piece of cast iron in it to retain heat. Keep in mind heat transfer takes time so the temperature of the pieces you‘re trying to temper shouldn’t be swinging nearly as much as the air temp in the oven. A large amount of the heat being put into the oven is being lost to the outside. A PID system would certainly be more precise but you might be able to slow it down by adding mass and/or insulation.
