Flycm HD-3000 Steadycam Stabilzer for DSLR Cameras
Dharmaspirit71
Feedback: +19 / =0 / -1
Designed to capture extremely smooth shots to put the edge on your videos that will show you are a professional video magician. Flycam HD-3000 is a professional, lightweight high quality stabilizer with telescopic structure that support camera up to 3.5 kg. Using this one piece of gear you can get beautiful and stable moving shots with a very high production value. And, since it weighs very less, it won't break your back when you need to hold both Flycam and Camera for extended period of time. WHAT'S IN THE BOX: Flycam HD-3000 hand held Stabilizer, FREE Heavy Duty Table Clamp, FREE Unico Quick Release Plate, FREE Storage Case. TOP PLATFORM: A Quick Release, no-tools, drop-on camera mount plate allows you to quickly attach or remove your camera. Plate has both 1/4"-20 and 3/8"-16 mounting slots (holes) to accommodate a variety of camera bases. Adjustments can be made using horizontal axis. GIMBAL HANDLE: Three-axis Gimbal incorporates several adjustable, convergence controls. It provides rotational camera control with easy movement. The extra comfortable handle moves up and down or side-to-side according to your need. WEIGHT PLATE: This DSLR stabilizer system contains weights to balance the camera on stabilizer. Add or remove weights as per your camera's requirement. TELESCOPIC POST: In order to adjust the camera's vertical balance you can adjust the length of telescoping Central Post, When balanced properly the camera floats, ready for you to move into action. UNICO QUICK RELEASE (QR-5) - Absolutely FREE: Quick Release Adapter is capable of holding medium format DSLR cameras and scopes. The reversible camera mount and extra-large mounting plate make it a best choice for professional photographers. TABLE CLAMP - Absolutely FREE: It is impossible to balance your stabilizer without this table clamp. STORAGE CASE: Flycam HD-3000 hand held stabilizer comes in foam lined, custom fit, protective Storage Case with easy tote handles.
Asking 115 Includes Paypal shipping and handling. Paypal friend and family or add 3% for goods and serviced. CONUS only.
