- Jun 11, 2006
With the upcoming tomahawk batch I have been looking at solving the quenching problem. My quench tanks would quickly overheat if I was doing more then a handful of these big blades. I looked at cooling the oil with heat exchangers and radiators. Also considered a water jacket around the tank or water cooling tubing in the tank. In my research I came across something called fog or spray quenching. I did a bit of digging and was quite interested in what I found.
In a nut shell water is forced through a misting nozzle. There is nozzles on both sides that face each other. The quenching speed is adjusted by how much water is sprayed or misted onto the steel. The graphs I looked at showed very impressive control on quench speed. The industry uses air powered mist/jets. Thy can adjust the air and water independently and really tweak the cooling curve.
just thought I would toss this out there. I’m working on putting together a simple setup to see how well it works for blades.
