- Jun 11, 2006
My plan was to start with water spray only. I have a dozen or so water spray nozzles with an output of 5GPH @ 100psi. My thought is to run it at 100psi and then through an adjustable flow meter that’s graduated in GPH I have another one that CC/min. I would space them eavenly out in a row down opposite sides of an aluminum pipe. There would be a catch container below. The water would be supplied from a tank that’s pressurized. My thought is that measuring actual flow of water to all the jets will give me an accurate way to tell water volume per jet. The jets have a spray angle of 80° So I will be able to have good And even spread.
Now for testing quench speed you could do a comparison test using oil and data logging the drop. I thought I read somewhere that thy use a 1” diameter nickle ball. I could embed a TC into somthing and data log the speed of my parks 50 vs the spray.
my thought is if you had the spray valved you could insert the blade between the nozzles and trigger the spray and the entire blade would get evenly cooled. Hell you could have it connected to a pid or arduino and program on off times or pulse lengths. Now my brain is running away so I better stop.
