- Sep 11, 2012
I've made two folders so far. The problem I'm having is that my blade rubs on one side when I close it. I have taken extra care to drill all the pivot holes straight. I did order the steel oversized and not precision ground. So I have to grind the flat sides to remove the surface, also to get it to a size that is manageable. I do know that I probably need a surface grinder but I don't have one. It's not warpage from the heat treating, I'm pretty sure it's the grinding.
I guess what I'm asking is, should I just buy the precision ground steel or is there any tricks or tips or maybe something that I'm missing on getting the alignment right?
