Folder blank dimensions
If you could only have one *folder* blank size, forged to reduce grinding - what size would it be? Looking for overall width, length and angle of blade.
Appreciate any feedback. :)
Jeff Kirchner
High Performance Alloys
That is sort of like saying ,"If you could only have one size car, what would it be?"
Different users will have different needs.
That said, a spear point blade would seem about the most useful in general use. 2.75" long, 0.60"wide, and 0.075 thick should be a good size. Bevel 3/4 up the side.
Stacy
If this is a blank I would want it 3 3/4 long square point and .095~.105 thick. With a long square blank I could make any blade shape I want. Also by starting with a thicker blank I could again take it to a thinner blade or leave the tang thick and step just the blade down to a thinner piece.
Stacy
Exactly - I am taking the Ford approach. Offer most basic item, in your favorite color - as long it is black. Dims will need to be large enough to make other items though.
Jeff,
I just took a look at your website and noticed you have one item in particular that you carry that I would be interested in. Are you interested in selling items in small quantities to knifemakers? If so please contact me.
Three inches seems to me a pretty standard size for folder blades, the width seems variable between 3/4" and 1".
Thanks,
Del
Well, I make small, medium and lager folders :)
3" is a pretty standard length but need another 3/4-1" for tang, 3/4" wide and .075" to .100" for thickness.
With that said, I couldn't work off one blank for my folders. Too many variables...
I appreciate all your feedback. I think we have a good start for our first forging die. If all goes well, we can look at others, just did not want to start in left field with no possible volume.
