Imho, if a folder is properly made w/ everything lined up and parallel/flat, the greatest hindrance to smooth opening/closing is the detent drag that occurs on the blade tang. This comes from the amount of tension on the lock bar (and of course the finish of the detent track to some extent). There is a fine balance between having the lockbar tension set properly w/ semi early lock up (~20-30%) w/ the right amount of force required to disengage.
For example, I've checked the lbs of force required to fully disengage the lockbar and detent ball on shirogorovs, and it's generally ~2 lbs. The 3 smoothest folders I think I've ever felt are grimsmo, shirogorov, and Brian Nadeau's Cyclone. I've got to examine each pretty well so that is a huge benefit to me. But his points about the flipper tabs have me thinking about slightly re-designing this with a little more 'deployment angle' - although this can be mostly overcome (as he admits in the video) with proper pivot action and detent lock up.
yes it's designed for 2 fingers to fit in the forward groove. In addition to moving the fuller up towards the spine, I could also mod the handle like this:
I'm also probably going to do several w/ out the fuller to allow for more options... any recommendations on percentages of those w/ vs those without? <- for anyone to chime in on...
I had not considered that but now that you mention it, that's a good idea. I wonder how much weight that would save. I do have an idea on an ultralight version of this for the future though, it would be sick. 2 x CF scales w/ a steel lockbar insert (no liners) and standoffs instead of a backspacer.
I'm not sure if captive pivot was the correct term to use. When I mentioned captive pivot in my first post, I meant something like this:I had a bunch of 1/4" pivots made to fit Hinderer XM18's so that's what I used in the proto and the 3d printed version (tools for this type pivot are very plentiful). But I think I will probalby switch for a double t-8 torx screws fastener w/ a barrel pivot. So this way, as you point out, it could be fully disassembled w/ a t8 and t6 torx bit. Either way it would be a 2-3 tool operation (since you would need another tool on the back-side of the pivot possibly).
I was looking over the structx chart, and it's very interesting. I've been meaning to try a high quality teflon washer one of these days.They can feel amazing, trust me. The hinderer he used in the video was not adjusted properly. When adjusted and dialed in properly the blade should basically fall shut or open w/ out any play.
I am setting this up from the beginning to work w/ a nice finger choil if desired. I think it would be really nice to choke up in a forward grip in certain circumstances.
Thanks so much for your input!!
I appreciate the time you took to respond! Its interesting to see how a knife designer is thinking through his process.
Have you considered the Hoback Rolling Detent? I'm not sure how the HRD is specifically designed, but I imagine that its similar to this:
The HRD is also slightly adjustable, so you can tune the detent break force to your liking and loctite it in. Plus there is less drag when compared to a set ball that is press fit into the detent hole.
"I have referenced this before, but it bears repeating--as the hand closes to tighten one's grip, the fingers come together. If there is something that impedes the fingers coming together is prevents you from getting the strongest possible grip. This came from Kyle Ver Steeg, a hand surgeon. Its something he has referenced many times and in doing some research of my own, it is 100% true."
Kyle is a knifemaker as well as a surgeon, and none of his knives have grooves. I have knives with and without finger grooves, and it doesn't make that much of a difference to me personally. But then again, I don't have that many opportunities to really "hard use" my knives. Since your knives will probably be more showpieces than hard used, I don't know if it will make a difference in the long run. but it's something to think about.
Just curious, how much does your wood bolstered prototype weight now?
Yes I am familiar and understood what you are saying, I'm just not sure I want to mess w/ it on this model. I do however, want to make sure the pivot nut isn't free-spinning w/ no way to capture that side (like on a shiro).I'm not sure if captive pivot was the correct term to use. When I mentioned captive pivot in my first post, I meant something like this:
where the pivot does not spin freely on the back side. That way you'd only need 2 tools. A t6 and a t8.
There are different ways of locking the pivot down. Detent balls, "D" shaped pivots, etc. Just an idea.
