Jager Blades, model is the Baron.@SCTorrero Incredible lineup! I’ll be back to share more thoughts tomorrow when I have a bit more time, but in the meantime can I ask what that top folder is?
Recently I have got excited by the idea of "ultra high" performance folders, where the maker pays much more attention than most to blade/edge geometry and heat treat. I am making this post to ask for recommendations in this regard, whether they're custom makers or production companies.
To give an idea of what I have in mind (and what I'm seeking more of), I'm thinking of guys like Alex Steingraber of Steingraber Performance Knives (SPK), or Kasé Knives Switzerland. Shawn Houston of Triple B Handmade would be another example but for the fact that he only makes fixed blades (at least currently).
When it comes to production knives, I may have run the gamut on those, at least as far as production knives that are available to purchase in the US. But if you can think of any slightly more obscure companies that may not be common knowledge an which fit the bill, I'd love to hear about them!
Usually the issue with a true hard use folder is that (obviously) the pivot area and/or lock suffers damage and fails. What if the handle/lock/pivot were designed in such a way and used materials that allowed for a ridiculous amount of flex/twist/bending/etc, and then this material being used would return back to it's original shape? What if the lock being used was one that allowed for a very high amount of self adjustment, that would self adjust to a certain degree during this flexing to keep the blade locked, but then when the handle material returned to it's original shape the lock would also return to a normal area of wear/adjustment? What if the pivot itself was also designed so that it could not be ripped from this handle no matter how much flex occurred (obviously nothing is indestructible, you can't twist the handle from the blade 360 degrees and not expect something to happen)? I'm no materials expert, but surely there is something out there that a handle could be made of that has properties like this. You would get a knife that could take a ridiculous beating but have the ability to absorb impact and flex so the damage threshold isn't crossed resulting in a failure of the pivot or lock. What kind of lock could provide this kind of adjustment/wear? Does anyone think this is even possible or am I just dreaming?Honestly, you mentioned the first two that came to mind: Alex and Roman. Transparent Knives does reblades and is very much of the philosophy you describe. Josh at REK does reblades and folders.
There is always Spyderco, which I really view as the gold standard here. You will not find a better performance knife for the price (specifically thinking of Seki K390 knives).
I know Mitchell Clark runs higher than typical hardness M390 with cryo, although I would not say his "focus" is performance. Strider, for all their problems, seems to know how to heat treat a knife (or have a good source). The 20CV Strider I had was the best I have had on my stones, but I sold it for other reasons. OZ Machine and CRK have stepped up their HT for magnacut. Hogue has too. Protech is working with Larrin on their HT.
I am sure there are others.
Spyderco
David Mary
Opinel - performance for money is insane
I don't know the answers, but they are cool concepts to think about. I do wonder if we are getting into "solution looking for problem" territory. For example, what kind of forces are we applying to a cutting tool that would necessitate this level of "toughness/durability?"Usually the issue with a true hard use folder is that (obviously) the pivot area and/or lock suffers damage and fails. What if the handle/lock/pivot were designed in such a way and used materials that allowed for a ridiculous amount of flex/twist/bending/etc, and then this material being used would return back to it's original shape? What if the lock being used was one that allowed for a very high amount of self adjustment, that would self adjust to a certain degree during this flexing to keep the blade locked, but then when the handle material returned to it's original shape the lock would also return to a normal area of wear/adjustment? What if the pivot itself was also designed so that it could not be ripped from this handle no matter how much flex occurred (obviously nothing is indestructible, you can't twist the handle from the blade 360 degrees and not expect something to happen)? I'm no materials expert, but surely there is something out there that a handle could be made of that has properties like this. You would get a knife that could take a ridiculous beating but have the ability to absorb impact and flex so the damage threshold isn't crossed resulting in a failure of the pivot or lock. What kind of lock could provide this kind of adjustment/wear? Does anyone think this is even possible or am I just dreaming?
thank you for your response.I don't know the answers, but they are cool concepts to think about. I do wonder if we are getting into "solution looking for problem" territory. For example, what kind of forces are we applying to a micro credentials malaysia cutting tool that would necessitate this level of "toughness/durability?"
That said, the idea that a tool could be fully optimized for performance (darn the costs or practicality) is really fun to imagine, imo. I'd check it out.
I want a knife to cut stuff. Any recommendations?![]()
Untitled by GaryWGraley, on FlickrWhich one is better slicer, a SAK or Spyderco Chaparral? Just based on experience or impression, thanks.
