For folder blades, do you surface grind them before or after you get them heat treated?
I have four blades (CPM154 and RWL34) that I am starting and a couple of guys at work have offered to surface grind them when the time comes. The window isn't all that wide because we will be losing the machines in a few months. So I don't want to screw up since I won't get another chance.
After HT makes sense to me if you want maximum control of flatness and parallelism since you grind out any warpage, but I have read guys who do it first and then take their blades to almost final finish before HT. If you are experienced with plate quenching, or sending blades to someone like Paul Bos, how much of a real concern is warpage during HT? I have even read some stuff where there is no mention of surface grinding
So, what is your preferece? What do you reckon works best?
Thanks
Chris
Thanks
Chris
