How To Folder Repair
https://imgur.com/a/WlkUCeJ
Hi all. This is my first attempt at posting pics. I will know if it worked in a minute. The attached are from folder which has the tip sticking out of the handle when closed. I took photos of the rear spring when closed, when open and when I am pressing the blade flat against the spring. I first thought to grind the tang until it rests flush. But if the spring continues to press down after the grind then I have made it worse and solved nothing. I can't pull the scales off as they are covered by sterling covers that appear to be epoxied on. Anyway I make kitchen knives which so far haven't needed a spring. The owner is a friend, and is very sentimental about this knife. What do you all recommend? If you need more info you can reach out to me directly at hfriedman1@outlook.com.
Regards
Trim a little bit off of the kick (tang) and see what happens.
I suspect the tip will go down.
Thanks Bill. I was hoping that someone with your background would answer. Is there a chance that the spring may deflect more and still pressure the blade forward after I grind a bit off the kick? I am asking because I don't have an understanding of how you all align the blade with the spring and how you keep everything in place. The assembly pins are not visible in this case. Great web page by the way.
Regards
You've got to post pics individually...
There ya go!!
There ya go!!
Thank you . Please realize that I put off doing this for all the years that I have been following Blade Forums. Not ideological, just dumb. I posted the images on Imgur. I only saw a way to move all of them with a hypertext. If I just highlight one will it pop up as a photo?
Went to your website. Beautiful work and an excellent selling site. Only drawback was I couldn't find your first name anywhere. Do you post on etsy as well?
Thanks again.
Not sure if this will help but it was suggested to me from the boys on The Porch and it worked out great. I just ground a little bit off the kick.
Thanks. I will try it this weekend. I'll post when done. Always appreciate the help. Regards
I used to carry a small lock back Buck knife that would do the same thing on occasion until the TSA took it away from me. Sometimes it was pretty obvious that there was pocket lint stuck in the lock, sometimes I could not see what caused it. Cleaning it always fixed it. I would start with that before taking it to the grinder. It's hard to tell from the picture, but it looks like there is a good bit of crud on it.
