- Nov 19, 2006
Why all this talk about how strong a folder is or should be?
I'm just sitting here reading about how folder X is stronger then folder Y and how folder A cuts better then B, etc.
Think about it. Has anyone been in a situation where you only have a folder and nothing else? I mean nothing! No object to use as a hammer or pry bar. Maybe you are on a island with no small branches or trees to break branches against. Or in a building with no chair or microwave to smash against the window. Or maybe you are stranded because your car breaks down or runs out of gas and all you have is your folder and the tire iron.
If you know you are going into a situation you will have a small fixed blade to aid in your quest. For example, Busse Active Duty or larger such as the SAR-4. Basically, you go prepared. Do you camp without supples or drive across country with informing someone or planning out where you are going and what equipment you will need? No, is the answer. If you do, Darwinism at its finest which equals less knuckleheads breathing good air.
Besides what in the world are you going to pry or baton with a 3.5" blade and a knife that is ~7" in total length? Be realistic; are you going to risk destroying your only knife in a "I'm on the show Lost" situation? I don't think so. If so, then refer to previous comment about Darwin.
See where I'm going with this?
What is a knife used for? Slice, cut, stab, and to scare the Sheeple.
