- Jul 16, 2005
$300 for a folder. really guys?
What is wrong with that?
I think people confuse the terms "strong" and "reliable".
If I have a locking blade, I want it to stay locked until I unlock it. It doesn't have to be horrendously strong, but it does have to be reliable.
I'm referring to strong. But reliable is changes in different situations. Reliable is an by product or effect of strong, don't you think.
I think lock strength is all about staying locked when using it for cutting. BAtoning may hurt the lock?, but the blade would be oriented in a safe direction and I don't see coming into harm from that.
The pivot pin would be more of a concern on breakage.
Also if using the tip to drill a hole, you'd want the lock to work.
The whole spine-whack thing never has made sense to me, as it's about SHOCK to the knife.
People want a strong folder because it does not make much sense to want a weak folder.
:thumbup:
you're right of course. but i was leaning towards that $300 would have been WAY better spent on a fixed blade.
I carry a folder a lot. It`s used for cutting. I carry a hatchet for "batoning", and for scaring sheeple I carry a gun. It all works for me, and has for years.
Has anyone pointed out that a $300 folder probably isn't as strong as a $39.99 fixed blade yet?
Why all this talk about how strong a folder is or should be?
I'm just sitting here reading about how folder X is stronger then folder Y and how folder A cuts better then B, etc.
Think about it. Has anyone been in a situation where you only have a folder and nothing else? I mean nothing! No object to use as a hammer or pry bar. Maybe you are on a island with no small branches or trees to break branches against. Or in a building with no chair or microwave to smash against the window. Or maybe you are stranded because your car breaks down or runs out of gas and all you have is your folder and the tire iron.
If you know you are going into a situation you will have a small fixed blade to aid in your quest. For example, Busse Active Duty or larger such as the SAR-4. Basically, you go prepared. Do you camp without supples or drive across country with informing someone or planning out where you are going and what equipment you will need? No, is the answer. If you do, Darwinism at its finest which equals less knuckleheads breathing good air.
Besides what in the world are you going to pry or baton with a 3.5" blade and a knife that is ~7" in total length? Be realistic; are you going to risk destroying your only knife in a "I'm on the show Lost" situation? I don't think so. If so, then refer to previous comment about Darwin.
See where I'm going with this?
What is a knife used for? Slice, cut, stab, and to scare the Sheeple.
Seriously, man, you're looking for reality on BladeForums?
A knife is used to cut. Most people don't need to stab, and if you do need a hole in something, a knife is too big, you'll be better off with an awl.
If I was in a situation where I had to pry with my EDC knife, I'd pry with it until it broke. But the chances of that happening are slim to none, so I would never base my knife needs on how much prying I can do with it.
Self defense isn't a concern of mine and I there people around here aren't afraid of knives, so I use my knives to cut. If I need to pry, I have several different sized crowbars and other prying tools. If I need to stab a hole in something, I have drill.
