Folders
Do ya guys have any good resources for design and build of folders?
Books, on-line sources, first hand accounts, etc.
I'm a ways off but interested so I may aswell study up while I build the requisite skills.
Thanks
Hoss, figure out which direction you want to go. If it is folders,then read....read....and read some more.
I started with fixed-blades, and after a couple of hundred, I decided to try a folder.......... Whoa...... A whole new learning curve.
Decide where you want to start, and give it a try. All the research, note taking, watching others, and everything else you can think of in the world will not substitute giving it a try yourself.
Go for it...... You'll never know until you try.
Robert
I'm not a huge fan of liner locks.
All else is fare game.
I aint got a much knife experience but a fair amount of other craft work under my belt.
Figured I would start reading up now.
Slip joints seem to be the easiest, then move up from there.
But what would I know?
I need more info myself...
Just wondering where an efficient place to start would be.
Thanks
Slipjoints are anything but simple.
Best book ever:
Slipjoints My Way, by Don Robinson
It walks you through a complete folder build, and even includes a pattern. It will take you from a know nothing to at least a basic level of slipjoint builder. Seriously. Great stuff. WORTH EVERY PENNY.
I'm getting ready to try a slip-joint build as well and have been researching the topic, and I'll share what I have found.
I'd recommend buying Don Robinson's book as mentioned above. He also seems to be available via email to answer questions and seems to like helping others build knives.
Chris Crawford has a dvd that is very detailed and walks you through the process, and he does a really good job explaining and showing the process on the video. http://chriscrawfordknives.com/#/how-to-build-a-slipjoint/4535205212
InI've found the following links on the internet that might be helpful...
http://www.culverart.com/Slip-Joint Folder Geometry.pdf
http://www.knives.mutantdiscovery.com/slipjoint1.html
http://www.medawebs.com/knives/tutorials/Slipjoint/Part1_Geometry.htm
http://www.americanbladesmith.com/u...Culver-Building a Slip Joint Folder-Part1.pdf
http://www.americanbladesmith.com/u...Culver-Building a Slip Joint Folder-Part2.pdf
http://www.texashuntingforum.com/forum/ubbthreads.php/topics/1484112/How_I_build_a_slip_joint_knife
http://www.ptartistry.com/slipjoint-knife-build.html
http://www.bicaksanati.com/forum/SharedFiles/slipjoint.pdf
