I ordered my GX6 kit on Friday and it was in my mail box on Monday.
The knife assembles pretty easy but I haven't started on the G-10 scales or drilling the pocket clip holes. All the screws are T6 except for a T8 pivot screw. Everything fits together nicely and the liner lock is pretty solid. I am buying some files and a respirator to work on the G-10. So far it is a pretty impressive kit.
I am on my 5th beginner kit and I have nothing but good to say about them.
For the money and if you have the time you cant beat the end result. :thumbup:
I just finished my GX6. My first kit and I must say it turned out pretty nice. I could spend some more time shaping the G-10 scales a bit more nicely but they are acceptable to me and I was getting a bit impatient. I wanted it done!
I didn't try anything fancy but the kit has a ton of possibilities. I can see how a more experienced person like TikTock can go all out on such a basic kit. I did put a small thumb groove in the G-10 near the thumbstud for easier opening. For the pocket clip I used the upper bolster hole as the center clip hole so I would only have to drill and tap 2 holes. The clip is nice and centered and the knife sits well in the pocket.
I built the entire knife with a hobby file set (broke one file) , 1 sheet of 220 wet/dry sand paper, and a Home Depot Torx screwdriver. My father's drill press was the only power equipment I used. I was going to use his bench grinder for the G-10 but once I began filing it didn't seem necessary. I did use a lot of paper towels and a water spray bottle to keep the G-10 dust down. I wore a respirator while filing and sanding, it was a few bucks at Home Depot. If I had all my tools and equipment ready I could have finished the kit in about 4 hours. Shaping the G-10 was the most time consuming part.
I'd like to post some of my photos. Can someone help out?
excelent work stevekt!!! i like the thumb groove!
i find that i want to get the knife done quik as well but i always go back and refine them more later on. some times just for funn.
Thanks justice and knife collector. If I really took my time I could get the scales to be closer to the exact size of the liner and make it perfectly flush with the bolster. I could have also made sure that they were mirror matches as far was rounded corners and such. But I was impatient and wanted my knife NOW! Still, I am very pleased with the final result. The little imperfections make it my own personal knife.
