- Jul 21, 2009
Gerber liner lock. After 2 years of light use, I noticed poor engagement and tested it. Moderate pressure on the spine defeated the lock easily. I blunted the the blade and threw it in the garbage.
Another was a Spyderco back lock on a Native. The lock and blade engagement got misaligned and the lock bar gradually sank below the handle. The blade wiggled up and down with pressure and it was replaced under warranty. It was about 7 or 8 months old and my daily carry knife for that time.
A Kershaw Ti framelock where the initial lock engagement was quite shallow. Also, the angles of the lock surfaces was fairly steep so a few wiggles back and forth would slip the lock out of engagement. A slight roughing up of the Ti surface and pushing the lock deeper manually eventually wore it in so the lock engaged more solidly.
Liner lock on my Leatherman Skeletool. The lock either fails to engage at all when opened with thumb alone or if flicked, the lock goes all the way down to where it touches the pivot. Poor tolerances and it's never consistent so I always double check before using the blade but that's rare.
An early version of the Spyderco Manix 2. The ball lock did not engage deeply and the spring pressure was not enough to keep it engaged. Moderate pressure on the spine would push the ball out of engagement. It was returned and replaced by Spyderco and some improvements to the lock design was made as a result.
