OK this thread niggled at me ..
The wire saw mentions in it anyway .
I bought a couple bulk lots over the last 10 years or so , I do that , buy a bulk lot of saws , emergency blankets , first aid kits ( a whole kit of quality the same as my pharmacist sells , but for $2 a kit instead of each item in it being $5 or more .. bargin ) put together a bunch of basic survival / emergency kits and either give them to friends or hock them for spending money online
hey , I have a habbit to support , I dont buy knives and gear with money that should be going to feeding the kids or keeping the mrs happy , I make that myself doing fun stuff I enjoy
( note , work is not fun nor do I enjoy it , work is a 4 letter word that ends in "k" and should NEVER be used in polite company )
Anyway , I read a linked review where they trashed a wire saw that looked just like the ones I bought and handed out .. that worried me big time .. Id hate to have been handing out bad gear , I dont care if I pay cheap for it , its still got to be good .. now I remembered using a couple saws to test them out and see if they were any better than the twisted steel strip ones I had bad bad bad memories of as a kid .. I found it to be a serviceable little saw , and had no hesitation to hand them out .
I got one of the few remaining ones out today to have a play with again after reading the review linked ... and you know what ? I reckon I can duplicate their problems , really easy . Just takes muscle . seeing a problem and forcing the saw with more muscle rather than rectifying or working around the problem .
I am used to treating a wire saw like a wire saw .. sawing with it using a gentle pressure , not expecting it to perform as a rigid bladed saw would , or to take the force applied to it as a hand chainsaw would . I dont think the guys doing the review did that ...
I pruned up my apple tree with my little wire saw .. cutting branches about as thick as my wrist at most . No problem .. cutting stuff that was about the size Id actually expect to cut to make poles for a shelter , it was a breeze . the thicker branches , I did have to pull the wire out to clear the sawdust out of the cut or it would start to jam up the saw .
I guess the thing to remember is , its a wire saw , light duty tool , designed to be carried in an emergency / survival kit , and used when you have run out of other options .its not a heavy duty saw and its going to suck if you try to use it like one .. it does require a different action to use it than a regular saw , it does require different amount of pressure as well or itll jam , and its not as energy efficient as a pruning saw either ... it does take slightly more effort to use .
what it also does do that a pruning saw or a hand chain saw doesnt do .. is fit into a tiny space and can be carried in an altoids size tin , along with a mini knife , pencil , paper , pain killers and other essential items for any emergency you may be preparing to encounter . .. and when you have to use it , itll do what its designed to , and do it well , with the qualifier of course , that the guy using it has 1/2 a clue what they are doing ...
I guess that like with all gear .. if you have never used it when times are good and there is no stress because of < insert emergency situation here > you are in for one very steep learning curve if you have to use it when the poop has hit the fan ..
I personally found that using the provided keyrings only as handles , a light pressure on the actual saw and sawing it at about a less than 45 degree angle , I got really good results for little effort .. tho granted it DID take slightly longer than my regular pruning saw , and the sawing action I am not familiar with .. Ill probably be feeling a little stiff in muscles I dont usually use tomorrow , I wont be using it as my tool of preference but i WILL be getting more of them and will still be feeling happy handing them out and hocking them off with confidence .
I do think tho , that like with any piece of gear , its cool to carry it just in case , but its even better of you take the time to learn to use it , so you are aware of what your gear can , and cannot do ..
My wire saw will cut wood , my ferro rod will start fires , my psk knife I made can and has been used to skin clean and part out game , and I have learned as a result of a troubled youth how to sleep fairly comfortably on bare concrete ...
I carry my saw and ferro rod and what I have learned for when I need to fall back on them because I havent got other options any more . they give me a hell of a headstart compared to having nothing .
If I tried to compare my wire saw with a rigid bladed saw and or hand chainsaw .. itd be like comparing sleeping on bare ground to different bedding systems , starting a fire with a ferro rod to differnt brands of camping stove , comparing m psk knife to a regular knife or a machete etc .. not really applicable or fair , but each tool and skill definitely has its place , and probably should be practised with .. tho I pass when I can on sleeping rough nowdays
anyway .. after all that , wire saws are not *all* bad .. but they are not as good as regular saws either .. a large part of how well they perform depends on how they are used . .
Im curious tho , at what point in a emergency / survival situation does one decide " ok , this is serious sheet , we are stuck ,no help coming for a while if at all , .. its time to begin using our gear like we stole it " ? every time its looked like things were going to be getting difficult for us , Ive always treated my gear with that much more respect simply because I was now even more reliant on it that before ...
