Great stuff posted here so far!! Thank you!
After looking into it a bit more, there are several options with these foot switches. It can be a simple on/off switch for starting and stopping the machine....but in 2 versions. Momentary, and fixed. For a momentary switch, your machine will run as long as your foot is holding the switch down...when you lift your foot the machine stops. A fixed foot switch allows you to step once to start it and it will continue to run until you step on it again. This will allow you to walk away or move around without having to hold the switch down.
The same options are available with a VS pot pedal for your VFD. It can be momentary, which will require you to hold your foot on it...or fixed, where it will remain in the position that you set it at.
Most of my thinking was for VS applications with a VFD. In this case, the switch carries a low voltage, low current "control signal" to operate the VFD. Things get more complicated on a single speed motor where the foot switch will handle all of the motor current...it would have to be a heavy duty switch...20 amps or so for a 1-1/2hp motor.
always thinking.....
-Rob
