- Jan 9, 2012
I have seen some of the videos for this and i have loved the old classic look given to it...
Four is actually perfect. It's surprising, but true. I have an RPN calculator program for all my PCs. It allows you to set whatever stack depth you want. I experimented with deeper stacks, but I am back to four.
...Man had climbed Mt. Everest, gone to the bottom of the ocean, he has fired rockets to the moon, split the atom, achieved miracles... all with four-deep stacks... and all without the use of an = key.
My HP-41C died.
My HP11C is still functional. Never got a 15C.
Thanks for the heads up, though. Have to think about that one.
Now that HP's sold out of the things, the secondary market's up to $180-$200. Sad that I missed out.
You could use Stirling's approximation....it can only go up to 69!, but to have it seize like that seems odd.
Be of good cheer: I'm sure they will have it back in stock, the thing to do is bookmark the HP web page where it's sold and check it every day like I did. Based on the serial numbers, I'm taking a SWAG that HP is maybe at 5,000+ units out of possibly a run of 10,000 calculators.
Now that I've had more time to play with it, I still like my HP32SII for a simple reason: it can calculate the factorial of a number greater than 69, whereas when I purposely did this with the 15C, the display kept blinking until I turned it off. In defense of the product, the manual states that it can only go up to 69!, but to have it seize like that seems odd.
Where are these new runs made?
I'm an electrical engineer working in new-product development.
It was my high school chemistry teacher, George Johnson, who really inspired me. He preached that you must not see a number as just a group of symbols, keystrokes. No. Numbers have meanings. They represent physical things. A weight, for example, represents the material being weighted. And this raises questions such as just how accurate the weight is, what unit of measure is the weight expressed in, etc. In chemistry or physics... or engineering, you must not separate the numbers from these other traits because you're not just doing math with theoretical numbers but are working with physical things.
He taught to always estimate before you calculate. You can catch a lot of errors this way.
He taught us about significant figures.
And he taught us to do "unit math" which is so important when dealing with numbers that represent physical things where you have units of measure.
He did not allow calculators. You either did all your math... and there was alot... by hand or you let him teach you to use a slide rule. His goal here was to expose you to the slide rule but, even more so, the underlying methods that the slide rule teaches.
I learned a lot of chemistry too.
He was one of the greatest... won the Dow Chemical Catalyst Award as best high school chemistry teacher of... as I recall... maybe... 1978.
