For the new beginners: Picture-tutorial of a knife being made on a budget.
Edit: I've come back and added more technique info for beginners. It's available elsewhere, but I thought to make this a more complete tutorial, I should add it.
I've noticed some new people to our forum, a few of which I recall being young, or on a budget. Anyone who wants to see how others are making knives on a budget should also check this out. :) Keep in mind, I'm pretty new myself ...any experienced members here that see me doing something wrong, please tell me. However, I understand the basics of working with my chosen steel, 1095, and making decent little knives. My tools, with the exception of a drill press and a large rusty c-clamp my dad had, were bought new. I don't have an exact tally, but it probably could've been obtained for under $100. At the end I'll make a list.
I first draw out the knife.
I then transfer the design onto the steel, and cut it out as best as I can with a hacksaw. I don't get too close to lines, typically. Also, the hacksaw cuts in a straight line, so keep this in mind when planning your cuts.
With this particular knife, my design was wider than my steel bar was, so i had to forge the tang a little bit to make it curve down. Don't do this for your first knife. Pick something easy.
I clean up the profile with files. I usually like a medium to large size half-round file for profiling, but little gremlins stole mine, so I used an itty-bitty round file for the finger-grooves.
Profiling: I clamp the blade in a vice, horizontally in front of me. Re-clamp the blade often, so the blade is always clamped near where you are working. I find this makes the blade vibrate less and generally file easier. Use smooth, consistent strokes, and keep the files perpandicular the blade, to keep the edges nice and square.
After my profile is cleaned up, I go ahead and drill the holes for the pins in the tang. Drill slow, and use a lubricant if you like. A drill press is indispensable for this. In the $50 dollar knife shop, Wayne Goddard says you can use a regular drill, but I'd really save up and try to get an old drill press.
Now I start beveling.
Beveling: Clamp the blade down securely, in such a way that you can move the file freely around the blade. You're going to be at this for a while, keep something to drink nearby and cancel your gym membership.
I start beveling by first cutting the plunge, moving on from there. You want the plunge nice and neat. I use one of my leather pieces on the clamp here to help guide the file while doing the plunge cut. Be careful that you're not eating into the leather too much, though.. Use consistent, smooth strokes, letting the file do the work (firm but sort-of light pressure) One method I read about for keeping the bevel even on both sides, is to first file a very steep angled bevel (a crude edge, really) to begin with, and make sure it is even on both sides, then start the actual bevel, having marked the center. The curve from the straight-ish part of the blade to the tip is the hard part for me. I haven't yet got a real good method for it. I like to make a sweeping motion, filing the whole curve in each stroke.
Beveled. (Finally.)
A side-by-side of the drawing and my ready-to-heat-treat knife.
I will heat treat the knife tomorrow, and post those pictures when I'm done. I will get the handle portion of this up as soon as possible, but it might be a week or two until my order of supplies comes in.
I've noticed some new people to our forum, a few of which I recall being young, and on a budget. Anyone who wants to see how others are making knives on a budget should also check this out. :)
Now I start beveling. Clamp the blade down securely, in such a way that you can move the file freely around the blade. You're going to be at this for a while, keep something to drink nearby and cancel your gym membership.
:p :thumbup: True, true!
Excellent execution!
So, how long did it take to get from the first picture there to the last picture?
Thanks for posting this!:thumbup:
Mike
mscantrell at gmail.com
GREAT TUTORIAL!!!!!
Your patience (and diligence) is impressive!
It's my guess that you now have to wear the "Italian Dinner Shirt" to work in because of the massive shoulders you've developed draw-filing!!;) :D
Really, though... all joking aside -- that's a great tutorial!
Keep it up! I want to see how you shape a handle!
First picture to last, was from 4:30pm to 2:30am, probably an hour or goofing off/eating. This knife was a pain in the butt to profile. I don't know what happened to my half-round file.
Nice work, you definitely proved it can be done inexpensively, but done well. :thumbup: ALMOST makes me feel guilty for buying a belt sander right away ;)
Edited for more practical information:
Ok, here's the heat treatment. It's in the oven at the moment, but that doesn't need pictures.
Here's the setup I use, everything I need, except my oven, to get the blade done up to the temper.
My heat treating setup, by itself.
Forge: The one-brick forge is a great tool for beginning knife makers. It's a soft firebrick (Ellis custom knifeworks has them. They cost about five bucks. I have my back closed, but I hear some people have it drilled almost all the way through, then a smaller opening to vent gasses from the forge. It has a hole coming in from the side, meeting the bottom of the inside chamber, for the torch to enter. The thing is wrapped with wire to hold it together.
This is my quench pan. I use a stack of broken ceramic tiles as a regulator block, to set the depth of the edge-quench. This is me checking the depth. I recommend a metal pan.
Quenchant: Olive oil, and automatic transmission fluid are two easy to get quenchants I've heard of.
Normalizing the blade (or letting it cool down a lil' past magnetic on accident to take the picture, actually). With the one brick forge, I like to constantly pull the blade slowly in and out, and flip the blade around, to evenly heat the blade.
Normalizing: I slowly (Propane knob barely cracked on, with the JTH7) bring the blade up to where my magnet doesn't stick at all, and then let it get maybe a tiny bit brighter color. I check for the magnet sticking often to make sure the blade stays the same temperature, and hold for 4 minutes or so. I like to heat treat at night. It helps me notice the specific shade of orangey-red the blade is when the magnet doesn't stick at all. I can better tell if the blade is a consistent temperature all over, than I could heat treating during daylight.
After normalizing, cooling down ...
Getting ready for the heat-treat, heating my oil-pan heater. Heat to around 140 degrees F. This is a "Pretty hot to the touch. Not quite scalding, but a little hot" temperature, if you don't have a good thermometer.
The quench pan and forge need to be close, to get the blade quenched in under 1 second. (1095 won't harden unless it goes from non-magnetic to around 400 (I think) in a second.) See how close mine are? Don't do that with a plastic quench pan. While I went inside to take this next picture, my one brick forge melted a hole through the side of my quench pan. I'll switch to a cheap disposable roast pan now, I s'pose. I tested the blade with a file, and it skated off the edge, not biting in. That means I'm good to go.
I'll get the polishing posted when I'm about to recieve my handle supplies.
This all looks eerily familiar. If the steel was O1, and came out of the quench with about a 70 degree twist at the tip, I'd swear I was having a flash back. Is your 1-brick-forge (1bf) open on both ends? Mine was drilled clean through, and I have trouble with blades over 3.5" long.
The one I used there is a closed back. I also have an open backed 1-brick with a little extension piece that caps the end back further. I've always normalized once, kept the blade very mobile during the heat treat, and edge quenched. I sometimes have a little lateral? (it won't lay down quite flat on its side) warp peaked around the ricasso, but that's it.
Yea, I'm convinced I over heated the steel, and ground it too thin. Its actually a testament to O1 that it didnt just crack and fall apart when it hit the oil. Also, my heat source enters the side in the middle of the heat chamber. I've read that it should enter at the bottom or top to let the heat wrap around the inside of the chamber, and not just create a hotspot on the middle. Off to find another brick.
Blue Dragon, it's refreshing to see someone fairly new in the hobby, take the time and effort to show us procedures, good for you! There's one thing that maybe Mete or Kevin can clairfy: You said: "The quench pan and forge need to be close, to get the blade quenched in under 1 second". I think what your saying is that you have one second for the blade to leave the forge and be in the quenchant. I don't have the figures in front of me, but what that is referring to is that once the blade is in the quenchant, it only has a second to go from Austenising to Martinising. I might have the terms wrong also(I appologise if I messed it up). One shouldn't be slow to get from forge to quenchant with any steel, but once 1095 is in the quenchant is where the critical drop in temp comes in to play.
I'm hoping to see more of your work, and this knife going through the rest of it's finishing procedures. You'll be one to watch for sure in the near future.
I get it there as quick as I can, lol. Going "One-one-thousand" as I move to the quench during my quench rehearsal, I usually hit it at "one-one-thous" :o
Sorry to have taken so long with this, and dig this old thread up. I was supposed to be able to finish the tutorial with the knife I started with, but haven't received my deposit/dymondwood money. If anyone noticed, I went back and included more information in the first posts... This tutorial was a little lacking in tutorial-ness.
I polished a blade I'm making for a friend, and put a handle on the 3rd blade I ever made (Lots of mistakes :o ). That will at least show my cheap-y methods. BTW, I use dymondwood because it makes a decent handle for some starter knives, it's in any color you want, and cheap. When I really start selling, I suppose I'll move to stabilized, fancy woods from the knife making supply catalogs.
First I put the blade on my "Backwoods beltsander" (Any stable, flat surface, really) and knock the scale off the sides. This also lets me see how straight the blade is after heat treatment. If it warped, certain parts will sand quicker, rather than the whole thing getting shiny at once.
Next, I clamp the blade down in a good position, and start the polish. I wrap little bits of different grits around a broken file tip, and push this along with my thumb. (The comfort of thumb sanding with the flat-ness of a wrapping around something flat :cool: )
I didn't really take any pictures of the initial forming of the handle scales, but I don't really have a set method anyway. I just take the scales, lay them on the blade, drill the pin holes, and after the 3 pins fit snug (but slide in and out well enough), start profiling the scales. I do cheat (as far as "50 dollar knife shop" goes) and use a hand-held belt sander turned upside down to help with this, but you could get it done with sandpaper, or maybe a really fresh, sharp rasp if you didn't get too close to the actual shape with it (I'd imagine a rasp would make dymondwood splinter a bit.) After the handle is almost perfectly smoothed down to the edges, and 95% done being shaped (I like to go ahead and polish where I slant down to the ricasso, too. Hard to sand there without scratching the blade, later), I'll epoxy the handle on. I haven't quite gotten the hang of mess-free glue-ups yet, so I won't bother explaining a bad method. :o
Here I am sanding the sides of the handle (post epoxy), looking carefully down the knife, making sure it stays perpendicular to the sanding block. I basically do this same thing (different angle) to bevel the edges of the handle a little (make it start getting rounded).
After I bevel the sides all around, evenly, I smooth that even bevel out into an even, rounded edge.
After going up to a fine sandpaper, I steel wool, then rub down vigorously with a old sock. (Really, Wayne Goddard explains all this much better than I do.)
Here's the blade with the handle done. I should have taken this picture by a window or something for better light, but didn't... so you can't see the blade too well.
Well, that's pretty much it. It takes a while to make a knife this way, but you can get reasonable results without spending a ton of money. One rule I like to try to follow, is to always try to make each knife to the best of my ability. To not let a stubborn scratch be there because it's "Good enough." It's a big temptation when doing it all by hand, but you'll produce a disappointing knife if you slack off like that. :thumbup:
This topic, and the words and photos of Blue dragon show us the real power of the internet.
At no other time in human history can one of us reach out to so many others with such ease.
The photos we can up-load bring people from across the word right into our own little shop.
A new person to knife making can show experts across the earth what he has for tools, and then ask for advice on how to use them and then show the results that same day....
We live in interesting times.....
Fantastic tutorial,as i am a complete idiot on even the basics of knifemaking this has been a real eye opener.Thanks for taking the time to post this thread.:thumbup: :) :thumbup: :)
Really neato tutorial. I like that you did the whole thing po-boy style. Nothing like making your own knife.
That is a great tutorial!
I'd love to see the one you started the tutorial when you finish it!
Going to the Blade Show?
I see your from the Great State of Georgia
Thanks for taking the time to share!
nice. Thanks. It gives me a few things to think about in my el cheapo shop.
