- Feb 10, 2007
Finally...I can afford Lasik.
Not to be a killjoy or anything, but could someone please explain to me the utility of a laser in a survival situation? For signaling, a regular bright light would be more effective, because it doesn't have to be aimed as carefully to be seen (and won't blind your rescuers). To start a fire, a lighter, flint and steel or matches in a waterproof container are all more effective and less fragile. What other uses could there be?
With a strong enough green pointer, no smoke is needed, the beam is visible for hundreds of feet at night. Presume the same thing would happen with the red one.
did you try to burn anything like balloons and matches? it shows several of examples on wickedlasers.
This is the only laser I would consider carying for survival use.
https://greatlandlasers.com/index.php
and here is a review of this laser from Doug Ritters Web site.
http://www.equipped.com/rescuelaser.htm
