For me, anyway:Thanks for the replies. I was actually going to ask when sharpening if you keep the blade in contact with the stone/hone the entire time (i.e. from heel to tip then tip to heel) or if you make a pass say from heel to tip and then pick up the blade and go heel to tip again, etc, etc. I guess the grinding action is meant more for reprofiling, or for re-edging very dull blades. The single passes are then for light/finishing/stropping work?
Its held up fine for everything, even pounding seasoned American beech (although it was tough going on that wood!). For stuff that's greenish it works great, no chipping, rolling etc. I even thinned it behind the edge a little more from that video, no problems.HeavyHanded I got a Condor Parang for Christmas. Searching for "Condor Parang sharpening" your video was one of the first results. At 2:50 into the video you say you are setting it up with about a 26° angle, with microbeveling about 32°. You're speaking of included angle I presume, not dps? How has that edge held up and do you use it on dried wood or greenwood only?
I'm not sure I have any good way to accurately measure it. I will say it is ground to a very sleek convex - there is no discernible break point. Not an FFG but pretty thin compared to factory, I ground it down until all trace of the original slight hollow and overbuilt convex were gone. The edge took quite a pounding on a canoe trip in October and didn't need any work after.HeavyHanded Thank you. This is my first heavier machete and I don't want to overdo it on thinning. If you have time would you measure the thickness 1/8" and 1/4" back from the edge?
^^^^^This.I always sharpened horizontally from heel to tip.
