For Trade: Kershaw 2420 PE
Feedback: +41 / =0 / -0
Kershaw 2420 Liner Action
3.5" AUS6 blade
4.5" handle, lightweight aluminum w/rubber inserts
Liner lock
Update #2: TRADED
It's just been sitting around not getting any carry lately, so I figure maybe someone can give a good home. It was carried a good deal, but never used to cut much. Some scrathes near the tip of the blade on the front side, some scuffs on the clip and scuffs from wear on the butt end. Blade edge has a small nick and some small spots, but it never sharpened so it does need it at this point. Handle is light and solid, rubber gives a good grip. Lock up is solid. Has a 90 degree stop on the action. It doesn't slow the opening any given sufficient inital force because of the smooth pivot, but it does gives you a little margin of safety when closing. It's not a low profile carry because of the size of the clip and where it's mounted on the handle, but the bend in the clip provides a well placed and positive grip point for your index finger.
Wanted in return: Don't have anthing specific in mind other than another folder of similar value/quality, so make an offer.
Emails can be sent to orangeman2000[at]mindspring[dot]com. Other scans (larger, better resolution) can be emailed to you upon request.
