- May 31, 2016
Gents,
I know this is kind of a weird place for this, but I am planning out a built-in grill/smoker in my backyard, and was considering putting an extremely high heat burner into the mix somewhere.
I do a lot of sous vide cooking and generally sear with a big propane torch, but I have noticed that the bigger torch I use the better the sear. Essentially, it seems that to the limit of my ability to test, more heat over a shorter time gives the best results. You achieve that 'perfect' crust while overcooking the thinnest but of underlying meat.
Now, I am probably overthinking this, but I have extra blowers and the like lying around, so my question is, has anyone used a forge burner to sear meat? If so, how were your results? I am hesitant to do it in my forge as I am guessing that the refractories aren't particularly good for human consumption. If I built this burner into the grill, I would probably go with a small overhead burner blowing onto a 1/2" seel plate surface.
Plan would be: light the burner, slide in the meat for 10-20 seconds (or whatever it takes) per side, heat directly from the burner, turn the whole thing off. Not planning on using indirect heat from the steel plate (though I have cooked steak like that in the past and had decent results).
Any thoughts? "You are a dumbass" is perfectly acceptable.
