Forecum FK-D009 is a wireless solar doorbell that made of ABS, has 36 different melodies to choose from. The doorbell is connected to receiver wirelessly at 433MHz, the distance from the receiver can be up to 100 meters away. The volume of the doorbell is set to 4 levels, from 20 to 80db. The doorbell is powered by a 150mAh rechargeable battery that takes 4 hours through the sun to fully charge and can then work 8 to 12 hours continuously.
Product Features:
● No power required, supports solar power charging, with 2 LED night lights.
● IP44 weatherproof and acceptable for outdoor use.
● Easy to install, simply plug the receiver into a power outlet (the plug-in receiver does not require a battery), then use double-sided tape to mount the button base on the wall.
● 36 different ringtones, 4 adjustable volume, from 20db to 80db.
● A huge range in open spaces, up to 100m/300ft performance range.
● Receiver with plug, EU/US models for optional.
The wireless solar doorbell has a nice design that suits everywhere, mounting is easy with the double-sided tape, without holes, cables and more: https://gearvita.com/forecum-fk-d009-solar-doorbell.html
Hot new products:
mi band 4
amazfit verge 2
Product Features:
Hot new products:
mi band 4
amazfit verge 2
