VANCE, you can seal up an opy pretty well without disassembling it.
Just take some 500 grit paper and give it a very light sanding to rough it up a bit. Make sure you sand down in the blade slot and around the blade pivot. I fold up the sheet of sandpaper 4 times to get it thick enough to be a tight fit. Wipe it off real good with a damp cloth. After it's dry, give it two light coats of Helmsman Spar Urathane, all over. I use a pipe cleaner to get down in the blade slot in the handle. Make sure you get the flat area on the top of the knife by the ring lock where you can see lathe marks. Thats the end grain, and if that area is not sealed, it will wick up moisture like a sponge. Spar urathane over that area will help a great deal.
After it's all done, there's one thing more you can do. A friend of mine is French, and his family really do carry Opinels. They take a toothpick, and lube the inside where the blade pivots with Vasoline jelly. Smear in, then wipe out exsess, and you have a darn water resistant Opinel. Crude but effective.
More pics of the Ethnic Chinese slip joint still made today by Kuo. A family business since 1870 located in Taipei, Taiwan.
http://i19.photobucket.com/albums/b188/oregun/05-29-2011KuofoldersrefugePuYicoin053.jpg
http://i19.photobucket.com/albums/b188/oregun/05-29-2011KuofoldersrefugePuYicoin047.jpg
Harder to find than hen's teeth.
Here is a link to a fine quality video of the maker, with knives, at his shop:
http://www.youtube.com/watch?v=v9rjVibk9Ms
