- Dec 13, 2008
We got a pyrometer and high temp K thermocouple in today..Built a heat treating muffle for the gasser..Its a two burner atmospheric gasser..The muffle goes out the back and front of the forge, end closed off with a guide and hole for thermocouple(probe is 10" long iconel). The guide keeps the thermocouple in the center off the muffle walls..Also the thermocouple is never exposed to the gas/reducing enviroment in the forge..Only the heat in the muffle..
Anyway after testing the thermocouple for accuracy (we have incubator thermometers accurate to less than a tenth of a degree) we slowly brought the forge up to temp.
At 2 psi and choked off "x" ammount it will hold anywhere you want in the 1500* range almost rock steady...I let a piece of steel soak for 8 minutes and the temp varied no more than 1* up and down the whole time
and it didnt vary often at that.. Did that several times. Steel reached non-magnetic right when it was suppose to.
I dont think you can ask much more of a atmospheric forge
Im pretty confident in this set-up..
