- Feb 10, 2010
This may be subjective but what is the recommended technique to get the best look out of a random pattern? After getting the billet to a flat bar I have used a bandsaw/grinder to profile, forged the stick tang then beveled with my grinder. These blades turned out pretty good but I hated to grind off all that hard work forging the billet! My thinking is that if I forged the bevels then after finish grinding it would appear to have more layers as I got closer to the edge. Is this correct? Once I forged a tip in trying not to waste too much and the pattern there distorted from the rest of the blade and seemed like the layers were too close to stand out after the etch. That may have just been my bar too since I'm pretty inexperienced and still don't know really what action will affect the pattern afterward. I will eventually experiment more but for now I figured I'd just ask. I'd appreciate any advice you might give me.
Also I'm planning on making some ladder pattern Saturday, enough for one small 5" blade and was wondering here too if I should grind or forge with this pattern. Thanks again guys.
