Forge repair
Looking to repair a used gas forge that just puchased, the inside lining is in rough shape. The forge is a three burner (whisperer) My question is what product to use, and procedure to use.
Thank you
Rod
Welcome to Bladeforums!
Let’s see if we can find the right forum …
attachment.php
You can take several different approaches depending on how bad the insides are. The whisper low boy is a good forge and worth relining.
I would only take out what is lose inside and leave the good stuff that is in place. You can purchase a product called bubble alumina from Darrin Ellis
Supply that works well to fill in the dips and valleys in the forge lining.
Turn the forge on its top and use a large putty knife and trowel the bubble alumina into place, making it level with the burner ports. Plug these with tissue paper so you don't fill them with the casting mixture.
Let the top dry in place. When that is done set the forge on its side and cast that. Do the bottom last along with the ends with the forge in its upright position. The door is best repaired with a 2 inch thick piece of kao-wool if it is burnt out. The bubble alumina is a little pricey but worth it.
You can also purchase a reline kit from the manufacturer.
Good luck, Fred
Thank you for the information, I sure will give the bubble alumina a try from Darrin Ellis
Thanks again
Rod
What Fred said...I was pretty much going to tell you the same thing. Lots of materials to choose from out there. Wear your glasses and respirator when working with the repairs. Who know what got baked into everything....Gary
Thanks again
Rod
Hi Rod,
I offer reline materials for the NC forges, for a little less then they charge....they're not up on the website yet, but if I can help in any way, shoot me an email or give me a call.
-Darren
Darren is the man to got to.:thumbup:I have a forge building tutorial on my site that it may help you.:thumbup:
