w Dave ( and others),
As you now know, the temp was barely half what it needs to be for welding. The surfaces can be pretty bad condition as long as they mate well and get to 2300-2400F. Some folks clamp the pieces in a vise, and stick/mig/tig weld around the whole seam. Then they "dry weld" the billet in the forge with no flux at all.
Another thing to know is that welding is not a process of force. Drawing out the steel later on is, but the actual weld is done with fairly gentle blows. As the weld "sets", increase the force. You will "hear" the joint set, and the sound will become more solid. When it is solid sounding, then work it harder and at lower temperature. If you pound with all your might at 2300F, the steel will not weld, and may mush apart or crumble.
What I will add is that "Burning the carbon out of the steel" is pretty much a myth. The layer of de-carb is pretty shallow unless the steel is held in an oxidizing atmosphere for an extended ( hours and days, not minutes) period of time. This layer will be ground off after forging out the billet. It is measured in hundredths of an inch, not tenths.
By adjusting the flame to be neutral or reducing and working in efficient heats, welding is pretty basic, and de-carb is not an issue.
Some things that helps determine when the steel is ready to set the weld are:
1) Look at the borax flux - It should be runny and thin. It looks like melted butter to me.
2) Use a length of coat hanger wire to check the steel. When you think the steel is ready to weld, stick the wire in the forge and if it sticks to the steel when pushed against it in the flux area...the steel is ready to weld. This is almost fool proof. As the ancient Chinese blacksmith said -"No stickie-No weldie."
3) If the steel starts sparking - like a sparkler from the 4th of July- it is too hot.....but only by 50°. It needs to be hot to weld. Few welds fail because they were too hot....many fail because they are not hot enough. A few sparks won't ruin the billet,BTW.
4) Brush off the steel with a steel wire brush after each heat, and before re-fluxing. Also wipe off the anvil face with a rag or gloved hand after each heat.
5) Work in short weld heats. The steel drops temp fast at 2300F, set the weld, brush off, re-flux, and put back in the forge. All forge welding is done at yellow/yellow-red heat and when the temp drops down to red, it is time to set back in the forge.Continue to do this in short heats until you have fully set the weld from all sides. By then the sound should be lower and more solid as the hammer hits. At this point increase the blows and forge the steel down into the red zone.
So, to summit up:
Weld between 2250F and 2350F
Set the weld gently at full welding heat
Solidify the weld fully, increasing the blows as it gets more solid
Work the heats longer and down into the 1800F area.
Draw out the weld at 1800F to 2200F
Grind the de-carb layer off the billet. This is usually about .010-.030". You should see the sparks suddenly start when grinding as you clear the de-carb layer. The sparks indicate carbon in the steel you are grinding. If the steel is low carbon steel, there will be less (or no) sparks than if it is high carbon blade steel.
Forge the welded billet into a blade at 1700F to 2200F - NOTE: Forging a welded joint/billet to shape below 1600F can cause the steel to de-laminate.
Grind the blade to the final shape, removing the de-carb from the forging to shape steps. This is usually about .010". Again, you will see the sparks shower off the grinding belt as the de-carb disappears.
