- Dec 4, 2001
I've been playing with making a pipe hawk, and doing it with wrought iron, folded head and eye, and forge welding the bowl on. Unfortunately no success yet. I'm up to a bright buttery yellow and the bowel just won't stick, or if it does it pops off when I start reducing it just a bit.
Basically I folded the eye around a mandrel and inserted a high carbon bit, and did a little preliminary shaping, but left everything thick, especially the eye. I ground the back of the eye clean, forged out a plug a little larger than the width of the eye and ground a curve in the end to match the rear of the eye. A small tac weld to hold it together and heated and fluxed. When it was at a high welding heat I dropped the drift in the eye and lightly smacked the bowel/plug to weld it too the eye.
I'm using a gas forge, am I just not getting hot enough? In the old days this would have been done with a coal forge, and probably a little hotter. Am I missing a technique?
I can split the eye with a hot cut and drift, but I was hoping to figure out how to do the folded and welded pipe hawk. I have no problem folding and adding the high carbon bit, it's the blasted pipe bowel that is giving me fits.
This is driving me nuts, any ideas?
Thanks
Thanks
