Forge welding questions?
I want to try and forge weld to peices of carbon steel toghether to make make a really simple tomahawk. I see people using expensive powders to do it. I was just wondering if I could use borax for flux.
You can also use sand.
Well, not just any sand and mot without some skill at forge welding. Fine feldspar sand is what is used. Beach sand may make a weld very difficult.
20 Mule team borax works just fine.
I always thought in was a bit silly, but when I weld a $10 bar shoe (horseshoe) i use the expensive iron mountain flux. When I weld a $800 knife, I use borax! I guess it's true, all you need to be a horseshoer is a strong back and a weak mind;)
Well, there is a little more to it then that. Low carbon steel is a little harder to weld, and I certainly don't put the same effort into preparing the weld. Scarf, brush, flux and go. Most of the time I'm outside in the wind in a forge that should be up to welding temp. A lot less variables in the shop on a Damascus billet.
