Yes, and one of them would be me
I've been living by many of the tips you've given us here over the years. Such as using known materials, engineered quenchants and................
known, precise temperatures
I think I understand your reasoning in this case though. Thanks :thumbup:
I am quite obsessive when it comes to that critical factor in an operation, in heat treating temperature is
everything so I want to know what it is and be in control of it within 1 degree if I can. In solid state welding temperture is only a conveninece to make the job easier the critical factor is how close you can get iron atoms to each other. Solid state welding can be done at room temperature if the surfaces are prepared incredibly well or the compression is sufficient to intiate the bond. These critical factors here are not possible for the average shop at room temperature so we throw heat into the mix to make the atoms grabbier and thus possible for us to do it with a tap from hammer. If there is a range of over several hundred degrees that I can weld at I will focus my attention elsewhere as that is well within my feeble eyes ability to control.
You would recognize my style quite well in how I prepare the steel for welding and how I design my forge. All of my steel is carefully ground clean on all mating surfaces before staking up. I get the flux on as soon as it can get gooey and stick, and before heavy oxides can get started. I am
very picky about my forge designs as I want to be able to control the atmosphere as rigidly as I could with an oxy-acetylene torch, oxidizing, carburizing or neutral and any degree between each, and it must heat evenly. I prefer certain weights and types of power hammers for welding as well as specific dies. Between each fold I grind both surfaces clean and get the flux on it immediately.
A pyrometer in the welding forge could be good for keeping track of trends and how various materials react to your processes, as long as you kept good notes. It could also be good for a new welder to keep track of the maximum temp you want to go with a particular steel. But I feel that the new welder could be mislead by watching exact temperature instead of the really critical area of surface conditions. Once you are over a certain temperature the forges atmosphere is much more critical than its heat.
On the bloomery thing, I did indeed mean the process of consolidation by forging after the bloom had been removed from the smelter. If you get sparks while smelting, your atmosphere is really messed up in the furnace and you are deconstructing iron, not making it. I do however really like it when I tap the slag deeply and there is a little glob of goo on the end of the rod that immediately turns into a sparkler show when it comes in contact with the outside air; there is only one thing that does that and it ain't pure silica
