Forged Drop Point Hunter, Forged Clip Point Dueling knife, Forged Clip Point Fighter
Feedback: +0 / =0 / -0
"KWAL'AKAHSHOCHEET"
1/1 Forged custom drop point hunter by the brother Bo from Iron Medicine Blades. Forged from recycled scrap d2 tool steel bar. Water stone sharpened on 1000, 3000, and 8000 grit stones.
Knife comes with basic warrantee as well does the sheath
Asking Price is $1100 delivered, Flat rate USPS Priority mail, Insured, tracking and delivery confirmation. Paypal payment preferred. CONUS ONLY
"First I'll take it" get's it, earliest timestamp get's priority
Thank you for your time and consideration, all comments and discussion are welcomed.
SPECS
•D2 tool steel
•10" overall length
•5 3/4" blade length
•4 5/8" handle length
•1 5/8" blade width
•6mm thickness at handle
•5mm thickness at blade
•Full-tang blade
•59 HRC temper
•Spalted Maple burl handle
•brass handle pins
•Traditional fine brass pinwork
•hand dyed and sealed deer rawhide and deer sinew sewn Sleeve-work
SHEATH
•Hand molded to knife
•Thick vegetable tanned cowhide
•Naturally sealed
•Belt loop can fit up to 1 3/4in belt width
•Right hand, left side cross draw
"teypohs'keemeechpahtlahnee"
One of the 4 knives Bo has been working on since march, this beautiful blade was the first of the four to be finished.
1/1 Forged custom clip point dueling knife by the brother Bo from Iron Medicine Blades. Forged from recycled scrap d2 steel with a heavier tang at 4mm and lighter 3mm drawn out blade, with the majority of the weight in the center of the handle to maximize the ease and speed of tip directional movement and parrying. Coupled with a custom low top sheath with perfectly balanced tight blade retention makes for fast, easy, silent, quick draws, and draw strikes. Water stone sharpened on 1000, 3000, and 8000 grit stones.
KNIFE SPECS
•9 1/2" overall length
•Recycled D2 steel
•5" blade length
•4 1/4" handle length
•1 5/16" blade width
•4mm thickness at tang
•3mm thickness at blade
•Full-tang blade
•58-60 HRC temper
•Naturally sealed Spalted Maple Burl handle
•Solid brass handle pins
•Naturally sealed deer rawhide and deer sinew sewn Sleeve-work
•Makers mark down spine of handle
SHEATH
•Hand formed to blade
•Naturally sealed deer rawhide entry sleeve
•Fine hammered and hand stamped brass-work sheath frame and accents from recycled antique brass
•Hand made hammer peened rivets from recycled brass
•Naturally sealed
•Belt loop can fit up to 1 1/2in belt width
•Right hand, left side cross draw configuration
"tlahmahkahskah'mahtsahton"
One of the 4 knives Bo has been working on since march, this knife was the second of the four to be finished. 1/1 Forged custom clip point fighter by the brother Bo from Iron Medicine Blades. Forged from a recycled piece of d2 tool steel. Water stone sharpened on 1000, 3000, and 8000 grit stones. Features a broomstick style handle and two 1/2in skull crushers at the butt end of the knife.
KNIFE SPECS
•11" overall length in sheath
•10 1/4" overall knife length
•5 1/2" blade length
•4 1/2" handle length
•1 10/16" blade width
•5mm thickness at tang
•4mm thickness at blade
•Full-tang blade
•58-60 HRC temper
SHEATH
•Naturally sealed
