I find your questions strange, and your reasoning flawed. With a three burner forge you can use it as a SINGLE burner, double, or.. a three burner forge for larger projects, using a firebrick block to make it larger or smaller as necessary. Versatility I do not have with my current forge. My first forge was open open both ends, and I didn't like it. I blocked it off with firebrick stacked behind it, it heated better, but eventually it literally melted the entire back of the forge off... Of course by then the Kaowool was falling apart. I tried to save it, and managed to get a bit more time out of it, but it wasnt worth the effort. My current forge is two burner. It heats VERY well to forge welding temperatures, even better than the first one did, in less time. But again the Kaowool was disintegrating and needed to be replaced... I cut it apart, and used firebrick Mortar to glue the firebricks into it. I truly love it now, and use it when forging layers together, but for a nine inch knife, I need to forge out a pice of pattern welded steel eighteen inches minimum to cut it in half, and its not long enough. I cut a hole in the back of it, and it works, but it takes more effort than I believe is necessary, moving the piece through the forge and trying to get it all to welding temp and keep it there... a forge that is longer, with an extra burner would allow the entire piece to be heated without having to fuss with it. (My Belief only I have not tried it yet.) Though I have used a three burner devil forge, and it worked, but I don't like the burners, they dont get nearly as hot as the burners in my two burner forge, AND the devil Forge I used the kaowool was already sagging and falling apart.
Quote" There’s really no reason to have a 3 burner forge, especially since you can only work on one section at a time.
One section of what? When my piece needs to be 20 inches long by the time it is forged out to the correct length, it IS one section???? One piece of material that can be brought to temp without sliding it back and forth multiple times trying to get it all up to the same temperature?
I freely admit I am self taught. I wanted to make knives, so I just.. started! I am making some nice knives and want to upgrade to meet the needs I am facing. To do that I need... (Want?) a larger forge capable of heating the piece I am working with less fussing and work... Yes, I could, use a single burner forge with a hole in both ends to do it, but thats not what I asked about...
The forge I used with three burners, took FOREVER to heat to welding temperature (Just a bad design?) So I want a better one, that I am prepared to build, but I thought I might ask and see if there is a forge that impressed the people here enough that it might be recommended, and would save me a lot of work. So, again, I ask, is there a three burner forge built with firebrick, instead of Kaowool that could meet my needs? If not? Okay, I will begin the process of building my own.
