- Sep 29, 2017
Hello there, I didn't see any topics about introducing yourself and getting started on the forums. If I missed it please let me know.
More than making knives right now I'm trying to make a shop, gather some essentials and think about a "routine" that will satisfy my personal needs.
I'm totally new to the hobby, I'm starting with anything and everything that I can cobble together. I've been a homeowner for 26 years so I have a little to work with. Primarily I have an air tank to use for my forge. I want to take the time before I cut on it, to get my burner built, so they match up correctly.
So this is where I'm at, "burner 101". YouTube seems to have value. I think that I have the fundamentals of a burner understood. Number one, no leaks, number two, double check for leaks, number three, [regulate] the gas pressure, use a [gauge] in order to know the pressure, a [needle valve] in order to introduce a specific amount of pressurized gas into the system and finally an [orifice] of the proper size in order for optimal.... delivery? ....mixture?
This is where I'm a little lost to be honest. Because with a [regulated], [gauged] and [gated] system I would think that the orifice isn't even necessary? or at least crucial? It's a forced air burner BTW. Perhaps only the naturally aspirated burners rely more heavily on a proper orifice opening?
Also it seems crucial to have a solid air-to-fuel mixture within the system before ignition. I installed into the pipe an Irwin 3/4" augur bit (with the hex shaft cut off and ground to a point) just after the (potential/future) [orifice] assuming that it will create good turbulence. Plus a 90° angle, a flared tip and a perforated plate at the opening.
TL;DR
Hello, I'm new here....
On a forced air forge burner, if I am using a regulator, a gauge, and a good needle valve is it crucial, important or even necessary to have an accurate orifice at the point of delivery?
-thanks
HBTR.
TL;DR
-thanks
HBTR.
