Forging process...What's yours?
I was just curious about what order some of you forge out a blade. I'm not talking heat treatment, but in what direction or to what shapes do you move the metal from beginning to end. Let's assume that you're starting with round stock. I do it this way:
  1. I take it from round to flat bar.
  2. I then forge it to the correct width and thickness for the design that I'm after.
  3. I then preform the tip.
  4. At this point I forge in a taper from where I want the ricasso to begin out to the tip on the back spine (I think this is called distal taper).
  5. I then forge the cutting edge.
  6. The ricasso is forged next, narrowing the width down just behind the cutting edge.
  7. The tang is forged last.
I used to forge the tang and ricasso first, but found that it becomes flimsy while I'm forging the blade and edge causing me to spend a lot of time straightening it back out.
How do you do it?
Scott (Ickie) Ickes
1. round to flat if I am using a round bar
2. forge point and taper somewhat
3. Establish plunge and forge out the first parts of the bevels.
4. establish ricasso/edge transition and bend the blade down.
5. Finish bevels and taper the rest of the way
6. forge the tang.
7. Spend a LONG tme refing the shape and making sure the damn thing is straight:D
Absolutely the truth,my friend!!!!! The big bowie that I am trying to get ready before Blade may be the first knife that I haven't had to "grind straight" to some degree after forging:D
For partial tang knives:
1. Round to flat
2. taper the point
3. forge the dropped edge/choil
4. bend it into the banana shape
5. forge the edge bevel
6. cut off of bar and forge the tang
7. then I normalize and anneal in my Evenheat.
For full tang knives with complex shapes like this one:
1. Forge from round to flat, usually have to widen it some
2. Forge in the distal taper and tang taper.
Then it's stock removal the rest of the way. I do all the normalizing and annealing before I saw/grind the blade to shape. This guarantees fresh steel (no decarb) on the cutting edge.
