- Jun 11, 2006
Oh!!! Yeah I forgot! That’s why the super mystical Japanese swords of centuries ago, could cut through anything! It’s because of the intensified super magic forging power of awesomeness!!
Uhg! Take some time and learn about steel & alloy. This is referring to parts made by forging vs CASTING! Little lesson for you....since I’m a gunsmith/firearm’s builder. Several of the firearms I build use RECEIVERS.... sometimes an upper and a lower. Forged receivers are always preferred to CAST receivers, as the cast can have air pockets, slight imperfections and almost microscopic deviations which can result in cracking.
But NOW....the new thing is BILLET RECEIVERS. These are CNC machined from a solid block(billet) of material, in really expensive 4-axis machines. Some are now saying these BILLET units are even stronger than their forged counterparts.
High alloy knife steel, as we get it in billets/sheets whatever...is NOT cast! It is hot rolled to, and then sheared/cut to sizes we buy. Guess what the hot rolling of the steel is??? FORGING!
And that ends the lesson for today!
Ok we will skip over the part where you claim to be an almighty gunsmith because you assemble LEGO guns. This does not impress guys that have actually designed and built guns from scratch.
I’m not trying to start a forging vs stock removal fight. I’m just trying to point out that there are benefits gained by forging blades to shape. But I digress, You completely missed what I was quoting and why. Forging alines the grain lines or flow in a direction along the profile of the part or blade. It has been proven that the alinent of these grain lines increases strength. And that cutting through them by machining or grinding reduces strength. It’s also not just castings that are forged, Lots of things are drop forged from stock. But in a way, you yourself proved that I was right in your last statement. You said knife steels are rolled which is forging. So A, we know these “super” steels can be forged and B, it’s a benafit to the alloys property’s. The issue with this rolled stock is the grain lines are all going one direction, for the most part. So when a knife is cut out of this stock you are cutting through all thoes grain lines. On the other hand if you forged the blade to shape you are moving the grain flow along the profile of the blade. If the direction and flow of these grain lines don’t matter then why do thy in testing? Take the Charpy toughness testing that Larrin is doing here. He says and I quote
“The sample dimensions would need to be as follows:
2.5 x 10 x 55 mm, with 55mm being in the rolling direction.” Because the rolling direction affects the grain lines which affects toughness. Mic - Drop
