If you forge weld in some powder you will need to put it into some sort of container. I use a 3x3 or 4x4 square tube. I normally make it about 6 inches long. I have seen others use muffler tubing to just fit the cable and drizzle powder into the can until you have to pack it in. The advantages of the 2 powders, pure higher contrast, 4% better edge holding ability but still good contrast. I normally use 2-5% with a high carbon powder. This way I do not have to worry about soft spots in the blade. make sure the cable is as clean a possible, do a nice long soak at welding temp. Wait until you think the whole thing is up to temp then wait 20 minutes. This will insure good welds.
Good luck and have fun
