So as the title says I forgot to raise the grain on a couple handles, I didn't have enough time one night so figured I'd get them all done except for raising the grain and sand it down and I'd do it to all of them the next day before starting BLO coats. Well obviously I forgot to raise the grain and sand down and have put a few coats of BLO on them, the only axes I've used that are finished with BLO have had the grain sanded so I'm not sure how much of a difference it makes when using them. One of them is a keeper and other 2 are sellers but if it is something I should remedy even if they were all sellers I still wouldn't say screw it and hope they don't notice cause that's bad business. So basically my question is if I just wet the handles will the grain raise like normal even with the BLO? Is it going to mess up the handles if I try and do it with it being finished with BLO? Or is it just not a big deal at all and it'll work its way out over time just from using it? If it won't affect it much I don't mind leaving it but if it's going to make a big difference I would like to try and fix it, just don't know if it's as simple as it is when the wood is untreated, honestly I've never had to sand a handle after I treated it with BLO except one of the first ones I did and I left too much on so it got sticky. That one was left looking striped cause I tried sanding it off and didn't know lacquer thinner would work at the time, the handle isn't ruined but doesn't look as good as it could. Long story short i know it's probably not a big deal but just wanted someone else's opinion on whether i should bother trying to remedy it or just leave it.
