- Jun 24, 2013
Hi, im currently working on building a cuirass, which is basically one armor plate on the torso front and another one in the back joined by straps.
Sounds like a cool WIP and I'd have done it but at the moment it's more QIP (question in progress) or maybe even FIP (failure in progress)
To form the armor I made a cast out of plaster of Paris and filled it with concrete. The concrete I smoothened with plaster of Paris.
Now I want to heat 0.16x24x48 ABS plastic (after drying it) and put it over the shape and let it be sucked down by a 2x4 feet vacuum forming table.
The problem is I can't fit that big of plastic into our oven.
What do you advice?
Could a heating lamp or 2 heat it evenly enough or would one part melt why the other is still solid?
Could I build a big box (wood+ aluminumfoil) around the vacuum forming table with the lamps up high, maybe add a fan and hope it distributes more evenly?
Should I forget about the vacuum and attack it with a heating gun starting from the most elevated part of the shape?
Maybe cut the sheet into smaller sheets 2x1.5 feet and shape them one by one? Would putting soft plastic on an already shaped cold plastic join both them strongly enough?
Thank you for your help and of course open to any suggestions based on real experience or simple brainstorming and out of the box thinking.
Thank you for your help with this.
What do you advice?
