https://imgur.com/EUyJFHN trying to identify this axe head I dug up metal detecting hope that someone here can help. Found near an old foundation near a lake in mass.
You should probably be asking a museum more than us, the thing is ancienthttps://imgur.com/EUyJFHN trying to identify this axe head I dug up metal detecting hope that someone here can help. Found near an old foundation near a lake in mass.![]()
Square_peg is probably right,though the patter of corrosion is an odd one.Normally,the higher-carbon bit would have a tendency to erode more that the lower-C/silica layered wrought.But conditions in different soils do vary very greatly.
Judging by it's general appearance my intuitive take would be that it's actually not that old.It looks regular enough to be a product of a factory-ish manufactury vs some small rural forge.
Very likely an import from Germany or France or some other part of Western Europe,in appearance a bench axe of some variety(maybe even single-bevel?).
(poll and cheeks are very Kent-pattern-loike
(all of the above Strictly subjective).
Or it's not wrought....Square_peg is probably right,though the patter of corrosion is an odd one.Normally,the higher-carbon bit would have a tendency to erode more that the lower-C/silica layered wrought.But conditions in different soils do vary very greatly.
Do you think I should try to clean it up, it would be a coll project to try to restore it?Thank you for the eye-view.
Yes,the eye would be consistent with most Kentish types.
But even if that is it's roots(or rather especially if so),then i'm more than likely wrong about it being a probable import.
Kent-pattern has flourished in the US right from the very beginning,many American manufacturers produced many a different axe with that type of eye/cheeks/poll.
if you're feeling dangerous, maybe a brass brush but it's pretty much a wall hanger at this pointDo you think I should try to clean it up, it would be a coll project to try to restore it?
I thought as much..thanksif you're feeling dangerous, maybe a brass brush but it's pretty much a wall hanger at this point
Thanks..It looks like a forge weld that is opening up. This can be caused by rotten soaked wood in the eye freezing and expanding.
that one's definitelly modern, probably a dayton or ohio2nd axe head found a few feet from first one.
eye https://imgur.com/EYOZ1oz
face https://imgur.com/XHG6nSj
Where was the find?https://imgur.com/EUyJFHN trying to identify this axe head I dug up metal detecting hope that someone here can help. Found near an old foundation near a lake in mass.![]()
