Found my favourite edge profile by accident - kind of...
Bear with me - the performance test is at the end....
This weekend I decided to make a large camp knife and try my hand at heat treatment for the first time.
I started out with a design that I had done a while ago. I had a piece of 8mm thich 5160 spring steel lying around.
(This was one of the reasons I decided to try heat treatment myself - apparently it is not a very difficult steel to heat treat.)
For this knife I did not want to have the profile cut using a water jet - this is a bit expensive for something I might screw up, so I had the blade plasma cut. Figured I would deal with the local hardening somehow...
Blade just back from plasma cutting:
I cleaned up the edges using a small belt sander:
Drilled the holes:
Then built a filing jig to do the bevels. I love my BK2 and wanted a similar bevel.
This was a lot of wasted effort and planning. The bloody steel was too thick for the belt sander. It started out fine but after a while as the bevel got wider the small belt sander simply did not cut it ( so to speak).
Gave up at this point and went to bed.
The next morning I decided to tackle the knife with the angle grinder. This went a lot faster and I kind of got used to the process of eying the blade and grinding off a third of an inch contour at a time.
This is where I ran into my first problem - I simply could not get the bevel line straight so I compromised by going for a full convex grind.
Nobody was around to take pics and I was in a rather foul mood at this point, therefore no pics.
I finished the blade with a couple of sanding disks 80 and 120 grit - this really evened out the marks made by the grinding disk and gave a much smoother finish. Took a while since I cooled the blade every few passes.
Afterwards I went back to the small belt sander with a rather slack belt to smooth out the profile.
Made a couple of mistakes with the belt sander like stuffing up the tip of the knife, but learned a couple of tricks in the process.
Heat treatment:
Heated to what I reckoned to be cherry red then quenched in warm canola oil.
After quenching:
Tempered in the oven for two hours. About 260 deg c.
Followed by some more grinding and making the scales from micarta.
At this point I ended up with a FULL CONVEX profile - no edge bevel at all...
Testing:
The blade is almost as hard as my Bk2 - tried scratching the two with the other knife's tip and neither really scratched the other. (Unscientific, I know....)
This evening I tested the blade on a wooden dowel - the cutting performance really impressed me. I cut up about a foot of hard dowel to see if it would dull the edge. At the end of my test the knife lost a little bit of its edge but could still shave hairs off my arm.
I then decided to compare the cutting performance with by BK2 which is just about my favourite production knife.
Procedure: holding on to the dowel with my left hand - knife in my right. Push cuts with my left thumb on the spine of the knife to sharpen the end of the dowel into a point.
Bloody hell!
The full convex grind needed FAR less effort than the saber grind of the BK2. It would take off larger pieces of wood with less effort. It could also shave off thinner slivers of wood with far more control.
Remember this is an 8mm blade compared to a 6.3 mm blade.....
The convex blade also bit into the wood at a much lower angle (probably about half) than that of the BK2.
It really felt as if I had switched to a softer wood. Did this test a couple of times back and forth between the two knives to make sure its not my imagination. Asked my wife and sons to try as well. Everyone agreed with my assessment...
For a final test I fetched my BK16:
Same thing - in terms of cutting performance to sharpen a wooden dowel, the 8mm blade with a full convex edge outperformed the BK16 too!
I really did not expect this - the BK16 is a MUCH thinner full flat grind (with an edge bevel, just like the BK2)
I think the difference is made by the edge bevel on the production knives.
Convex and BK2's edge...
Ended my testing by trying to make a feather stick out of a match.
Crappy photo, but heres a spine shot with the new knife and a BK2:
I still have a lot of other things I want to test my project knife on, but so far I have really fallen in love with the full convex profile....
Part of the difference is likely the difference in thickness right behind the edge. Also, you'll find that the BK-16 and BK-2 actually have the same grind angle. The BK-16 is just thinner at the spine because it's a narrower blade.
You made an Opinel writ large!
Yeah, what 42 wrote, and that is my main issue with the kind of camp knife ESEE and KABAR make - way too thick at what they call "the edge." There is a reason hollow ground blades have been so popular for so long - they remain quite thin behind the edge for many, many, many sharpening cycles and cut so well as result.
I like it.
Thanks!
I can now see why the guys love the convex grind so much!
Yesterday I managed to not screw up the Kydex sheath. Retention is almost perfect and the Kydex shaped quite well:
I still need to make the belt loops - thinking of scout style for this one.
