Hal Golightly
- Jan 1, 2007
Six Flashlights
1&2- I have 2 Lumintop GT mini Pro 3500 Lumens (both include extension tubes) LED High Intensity Outdoor Flashlight Available.
3,500 lumens output
Over 57,753cd beam intensity, over 480m beam distance
Runs on one button-top 18650 or 18350 with the included short tube
User interface: [1] Default Intuitive Narsil smooth RAMPING UI. Instant access to a 2.5 A TURBO mode is also provided. [2] Conventional discrete level MODE-SET UI is available. [3] MOMENTARY mode.
29.5W, 9A FET driver. Parasitic drain while OFF is ~27 μA.
Anti-reversed design, prevents reversed battery installation
43 mm ID, aluminum, smooth finish
Aluminum with Type III hard-coat anodizing
Tactile with back-lit rubber boot
Equivalent to IP68, underwater 2 meters
Size: 50 mm Ø head x 132mm length
N.W.: 150g without cells
Made from durable aircraft-grade aluminum.
Compatible with CR123A, 16340, AA, and 14500 batterie
Both flashlight ncludes box it came in and extension tube. $30.00 each or both for $$52.00 shipped USPS insured.
3-JETBeam RRT-0 Raptor with Infinite Ramping LED Flashlight
The JETBeam RRT-0 Raptor has been updated with a slick new feature, a variable output ring that allows you to go from 0.003 all the way up to 255 lumens and everywhere in between with a simple turn of the rotary ring. The light uses CR123 or 16340 batteries by default and can take AA sized batteries as well with the use of the optional extender. No Box or papers. $45.00 shipped USPS insured.
4&5-I have 2 JETBeam WL-S1 was designed with camping, hiking, fishing, and other outdoor activities in mind. This multi-functional flashlight features 5 brightness levels, a strobe mode, and SOS mode. The WL-S1 can be easily carried with the included removable clip or a nylon belt sheath.
Features:
Compatible with CR123A, 16340, AA, and 14500 batteries.
Toughened ultra-clear mineral glass with double-sided anti-reflective coating.
Reverse polarity protection.
PX-8 waterproof rating (up to 2 meters submersible).
Mode: Output/Runtime
Turbo: 700 lumens/1.3 hours
Max: 160 lumens/1.5 hours
Economic: 70 lumens/8 hours
Low: 26 lumens/37 hours
Weak: 1 lumen/300 hours
No Box or papers. Each light is $30.00 or both for $52.00 shipped USPS insured.
5-Acebeam E70-AL EDC Flashlight features a double-inner barrel hollow design that improves heat dissipation efficiency, its lockout design prevents accidental activation for safety considerations. Powered by 21700 Li-ion battery, the E70-AL delivers up to 4600 lumens and reaches 262 yards (240m), guiding you through any situation in the dark. Dustproof, waterproof, and impact-resistant to 1.5 meters. Was $55.00 now $45.00 shipped USPS insured.+
If you buy multiple flashlights I will take an additional $10.00 of the total cost of the total for purchasing at least two flashlights. Thanks for looking.
3,500 lumens output
Features:
