db said:
Are you now saying skin does compress?
Yes, read the above posts. Your skin readily compresses until light loads, and then stops compressing allowing the application of heavier forces. If this wasn't the case you could not actually depress a back lock.
Is there no tork involved when a frame lock fails.
When you apply force to a frame lock you are directly opposing the force on the lock, thus there is little torque, the main issue is simply a force balance.
If however you try to stop a slip joint from closing by apply a force to the blade and one to the back spring, the torque would mean that the force on the backspring could be at a leverage advantage of about a factor of ten. This is a rather large effect obviously.
Anyway, concerning your idea about slip joints and lock backs, I took a Gerber Gator and using my index finger and thumb pinched the tip of the lock release behind the blade tightly. I then had several friends try to depress the lock, they either could not or found it massively more difficult.
This would be trivial to show using weights on the lock release to show that the release force was greater when I applied force to the top of the lock bar. The same would hold for a slip joint if you applied heavy resistance to the backspring.
If you really can't see the physics involved is no different than actually depressing the lock bar, I could video this and put it on line. I have a few other vids I should be putting up in a month or so, depending on when various knives get here and when I get around to doing certain things with them.
Can you change your grip to reinforce a liner lock, sure, however naturally when your grip tightens on a liner in normal using grips, it acts to unlock it, thus the "white knuckle test", on a integral it acts to inforce it. If it could not do one, it could not do the other as both are the exact same dynamic and it is *much* easier to reinforce an integral as you can apply force directly to the bar, whereas with a liner it is indirect across the top, and thus you are just getting a side effect of a shear.
-Cliff
