- Jan 11, 2019
Hi everyone,
I haven't been around much lately. My wife and I bought an apartment and moved house, so there was a lot of work involved.
As a big benefit there was the garage that came with the apartment, it is an independent building about 45 m2 in size, and it shares one wall with the neighboring garage and has a car port in front of the garage door.
As you will see, the garage had/has quite a big problem with water ingress. While I noticed that there is a problem with humidity I was not aware of direct roof leaks and further damages. There were only small signs of trouble in the summer, but the whole thing went to sh*it during the fall and winter.
See for yourself below.
Anyhow, I thought it would be nice to share the repair project with you and to document my progress as I go. Your ideas, comments and help are more then welcome as I am doing a lot of this small repairs and fixes for the first time.
Finally, I will be sharing my ideas on the lay out of the shop , tools and similar and would love to hear what you have to say on it.
Drive in from the car port. New to (to me) workbench with foldable vice and a rocker arm for putting it on wheels.
Street view.
The flat roof was covered with some kind of waterproof asphalt which cracked on the lower side of the roof so the water was going directly into the wall, the whole roof is now professionally repaired with bituminous sheeting.
I cleaned up the mess behind the garage.
Still to check if this corner needs to ne unearthed and checked for damages/water leaks.
Crack between the garage and outside wall (water ingress number 2) provisionally repaired, it will be covered with metal sheeting to provide additional protection. I guess this was the source of the water damage in the lower part of the wall, water was passing from the roof and dripping before reaching the water drain directly in the crack.
I would like to unearth the garage further, but the roots from the neighnours tree and proving to be a formidable opponent.
Street view.
