- Jul 13, 2011
Freehand sharpening is the bomb
It's zen
Yeah on a hard stone you're just sharpening at a lower angle than the actual cutting edge and gradually lifting the angle to the desired end angle to blend the transition of geometry into a gentle curve. Some folks use a rocking stroke against the stone, but that gives less consistent results. Regarding scratching the sides of the blade, that comes from dropping the angle TOO low so the stone is contacting the primary grind rather than the shoulder transitioning between the primary grind and the secondary grind (the actual edge.)
Just in case... 1075 Carbon steel, micarta handle, 3/16" bladestock; 11" blade and 17 7/8" overall length according to their catalog. Weight 1.35 lbs.
I want one too. That's another thread however.![]()
Bro I know this is off subject but I started this thread
You have a Condor Boomslang, it may be my next purchase but I can't find specs on the thickness of the blade. What is it bro, you can pmoore me if you like. Thanks & be blessed
What 22-rimfire said. It sort of applies, though, because unless you get a Special Grade one from me then you'll have a lot of sharpening to do!The present factory edge is way obtuse so I thin 'em out for now until they fix it at the factory and that production filters down. They come convex anyhow, though.
With regard to your last question, My edges have the shoulders of the transitional geometry convexed, but I just freehand sharpen the actual edge itself and don't worry about maintaining a "perfect" convex as much as shooting for a consistently thin (usually 30-degree included) angle.
If you sale them pm me bro. I hope this was not against forums rules.
I like thinner convex edges also, on a chopper at least 3/8" tall & around the 30 °ish.
