Im mainly asking about grinding bevels, ill look in to that for sharpening and doing edge profiling though thanks man!I reprofile with it, that's grinding. Belts are called belt grinders - people sharpen with them also.
Ive been grinding freehand also, however I really like that tilt table!!I use a rest similar to Dan Berg's tilt table. Solves the issue of grinding the belly/tip area. Game changer for the quality of my bevels.
https://bergknifemaking.com/products/tilt-table-knife-bevel-grinding-jig
Depends on how far you grind a relief into the back of the table. I ground about a 3 or 4 degree relief, so that's the degree of grind I can do.What is the minimum Flat Grind angle you can set with the Berg table ?
